Raise The Floor Level - Flooring - DIY Chatroom Home Improvement Forum
Old 02-18-2010, 02:52 PM   #1
Rewards Points: 282
Raise the floor level
One part of area is my room has a drop. It is almost 6" stepdown from the rest of the room. This is because, the earlier owner, joined part of car garage and breezway and made it a big room.
Car garge is 6" is higher than the breeze way.. Now I want level this floor. In order to do that, I need to to raise breezeway floor to 6".
How do I do that ? What is the general practise ?
Here is the pic : http://i699.photobucket.com/albums/v...r/P2150084.jpg
cprao is offline   Reply With Quote
Old 02-22-2010, 08:29 PM   #2
Rewards Points: 282
Any responses ?
Old 02-22-2010, 10:49 PM   #3
What's underneath ? Concrete ?
Do you need (want to) insulate ?
If concrete you put down vapor barrier, frame it out & put a new sub-floor down
Old 02-23-2010, 12:03 AM   #4
Civil Engineer
Rewards Points: 4,560
By code the car garage must be lower than the house. This is to minimize the chance that spilled fuel will move from the garage to the house. Even if you make the garage level with the house, I don't think this meets code. You need to check with your local code enforcement official before you go any further.
Daniel Holzman is online now   Reply With Quote
Old 02-23-2010, 12:42 AM   #5
Rewards Points: 282
Underneath is concrete.
So step one is put a vapor barrier.. is it a liquid ?
Frame it - which is similar to drywall framing, right?
Old 02-23-2010, 12:44 AM   #6
Rewards Points: 282
It is no longer the garage.. It is part of the house living space since 1972.
Surprisingly this lin line with the house concrete level. Only the breeze way was at lower level.
Old 02-27-2010, 12:52 PM   #7
Rewards Points: 282
What kind of framing I should do.. It is close 6" drop. I need to raise that to 5.5 inch so that I can put 1/2" plywood on top it to make it in level with the other floor. How do I do it ?
Old 02-27-2010, 01:14 PM   #8
Best to use 3/4" plywood, just carpet on top as finish ?
So 5.5" - .75 = 4.75" floor joists
You would need to cut down 2x6's to fit
Vapor barrier usually is plastic - 6 mil
Old 02-27-2010, 04:57 PM   #9
Rewards Points: 282
Since I already have a concrete, I think I should be doing the following.
1. put vapor barrier
2.Create a rectunglar frame 2X6.. Fit this frame into the area which is 3 sides walls and one side drop.
2. insert 2X6 (actual is 5.5) into this frame.. are these called as floor joists ?
3. cover it with 3/4" or 1/2" plywood whatever is appropirate to make it level with othere are.
Am I in the right path ?
I do some questions but I will ask once I know I am in the right path.
Sorry for all these questions.. Never done any construction..
Appreciate your help.
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 10:13 PM
Raise Floor For Bathroom Plumbing Expansion ? fliteking Plumbing 1 11-16-2009 08:08 PM
Raise or move light above vanity!? Mike2181 Electrical 2 09-21-2009 01:35 AM
How To Raise the Floor in 2nd Story Bathroom oneangie Plumbing 2 08-01-2009 10:21 AM
Using a jack to raise joists drhowarddrfine Flooring 2 10-22-2006 09:42 AM
