Raise An Exterior Door To Compensate For Higher Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 08:58 AM   #1
Unhappy
raise an exterior door to compensate for higher flooring
I am installing a new tile floor for the first time. I have a problem with my (steel) exterior door clearance after the concrete backer board and tile is installed. The floor would be too thick and I need to trim the door. (Is this possible???) Furthermore, I need to know how to raise the threshold up over the new floor.
rickcotc is offline   Reply With Quote
Old 09-04-2011, 09:16 AM   #2
DIY staff
Rewards Points: 7,174
There are several ways to address that----a lot depends on your skills and needs.
If the door is old --often removing the door and frame and installing a new one at a higher elevation is the easiest way.
Steel doors can be cut and a new bottom installed---then remove the old thresh hold and install a new one---that is actually harder to do than installing a new door--
tpolk (09-04-2011)
DuraFlex Epoxy Flooring Problem Amon Flooring 9 11-04-2013 12:47 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Raise the height of my sub-floor in prep for laminate flooring chrisrod Flooring 0 10-30-2010 03:56 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
