Old 06-28-2006, 12:58 PM   #1
Radiant heat under laminate
We are thinking of putting electric radiant heat under laminate on our first floor (concrete slab). I am currently looking at QuietWarmth by ThermoSoft. They seem preferable to some other brands to me because the wire is in the padding (ie I wouldn't need both padding and heating layers) and because they offer quantity discounts (we will be doing about 300 sf). Has anyone used this? Does anyone have any recommendations/suggestions/warnings about this product or about electric radiant heating and/or laminate flooring in general? We will be doing this ourselves, though we will hire an electrician to put the gang boxes in.
Thanks for you help.
sierraac is offline   Reply With Quote
Old 06-28-2006, 01:24 PM   #2
Floorwizard's Avatar
keep the humidity up so the lam will not shrink as much.
Floorwizard is offline   Reply With Quote
Old 08-21-2007, 01:43 PM   #3
Not-So-Newbie
No matter which brand or type of electric radiant heat you choose, make sure the company that manufactures the flooring will warranty their flooring with radiant heat. Most do now days, but there are some who dont, due to the fact that the adhesives used in the manufacturing process will not stay strong with prolonged elevated temps.
Steven62 is offline   Reply With Quote
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 09:58 AM
Electric vs. Hydrolic Radiant Heat art2670 HVAC 2 08-23-2007 04:51 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
Need radiant heat advice steve stas HVAC 2 04-27-2007 09:04 PM
Radiant Heat Flooring As Only Heat Source? digthisbigcrux Building & Construction 2 03-10-2007 12:33 PM
