Radiant Heat Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 01:27 PM   #1
radiant heat floor
i have radiant heat in my bedroom. i have had it replace twice in two years the floor is fine untill the heat is turned on then it separates and buckles what is wrong the manufactor says the floor is designed for radiant heat
jimauto is offline   Reply With Quote
Old 02-17-2011, 10:46 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
First - welcome to the site.
I don't have any answers, but I suspect you will get more responses if you provide a bit more information.
What type of radiant? Electric, hydronic?
What type of flooring? Hardwood? Engineered wood? Laminate?
What type of sub-floor?
Where are you located?
Stuff like that.
Pics are always a plus!
Old 02-17-2011, 08:11 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yup! Have no idea what you are talking about without more information.
Please answer the above questions and we'll see what we can come up with.
I have one more question: Do you have and regularly use a dehumidifier?
XXX
Radiant Floor Heat question - suspended slab quadradeuce HVAC 3 12-27-2010 09:18 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Tile on concrete floor with radiant heat shutterjen Flooring 4 12-09-2009 11:22 AM
radiant floor heat installation issue pauln Flooring 9 09-04-2008 12:19 PM
Tiling on Above sub floor radiant heat jelly Flooring 14 08-05-2008 12:24 PM
