Radiant Heat And Cold Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 10:57 PM   #1
Radiant Heat and Cold Basement Floor
Hi all - long time reader first time poster.
I'm putting down a radiant heat floor under my new tile in a basement bathroom. I've decided to go with the Suntouch radiant heating pad package. My question is this -
1. All reviews of the Suntouch product look good on homedepot.com, anyone have any experience with it?
2. Should I lay down the insulating cork below or will it be fine without?
3. If I don't put the cork down, will the floor be noticably warmer or will I waste my money? I live in Colorado.
RidgeRunner78 is offline   Reply With Quote
Old 10-13-2009, 11:06 PM   #2
Civil Engineer
Rewards Points: 4,790
I put in a very similar system in my kitchen, but used no cork or any other insulation under the tile. My install included wire in thinset over subfloor, Ditramat over the subfloor, then stone over the Ditramat. I did insulate the basement ceiling using foil covered bubble insulation (not sure exactlly what it is called, comes in long rolls at HD), but I am not sure it really makes the floor above any warmer. I will say the kitchen floor feels great in the winter. Also, the foil based bubble wrap keeps the aliens from reading my thoughts when I am working in the basement, so I guess that is a plus.
Daniel Holzman is online now   Reply With Quote
Hydronic Radiant Floor Heat KGP HVAC 22 05-02-2011 08:31 AM
Replace forced air heat vent with radiant floor malfunction HVAC 9 02-05-2009 12:01 PM
Radiant Floor heating in Basement? mfleming HVAC 3 06-10-2008 08:22 AM
Basement ducting size??? firemanpato HVAC 1 01-15-2008 05:04 PM
