Old 04-28-2010, 02:58 AM   #1
Question
Radiant Floor Heating Question?
I am installing a bathroom in my basement and due to the concrete floors being colder than I would prefer I am going to put a heated mat down. I have all the electrical run and I am basically ready to buy the mat and the thermostat. I like the nuheat mats but I really do not want to spend a couple hundred more dollars on the nuheat thermostat. My question is are the thermostats all the same if they are GFCI grounded radiant floor thermostats rated for the same voltage. I like the LATICRETE thermostat due to the price and the ratings it has received but on all of the websites it pretty much says that the thermostat was designed for this particular mat. I think this is bs as they want you to buy their thermostat. I could use some help on this one. Thanks guys and or gals.
ryan5068 is offline   Reply With Quote
Old 04-28-2010, 06:51 AM   #2
Doer of Many Things
poppameth's Avatar
www.warmtiles.com
We use their product almost exclusively. Much cheaper than NuHeat and just as good. NuHeat and Warmly Yours are both built more on marketing than technology.
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
oh'mike (04-28-2010)
Old 04-28-2010, 07:24 AM   #3
Thanks for the info on a different company but I am looking to see if I can use a thermostat that is "not designed for the mat company" So for instance can I use a Nuheat thermostat with a Warmtiles mat? That is my main question. Thanks
Old 04-29-2010, 06:55 AM   #4
Doer of Many Things
poppameth's Avatar
I wouldn't. It's likely possible. I know I've tried to order a WarmTiles kit before and the manufacturer was out of Thermostats at the time. They offered a different Thermostat that they felt was just as good as the original one. But at the same time, they are made by the same company. It's possible but risky. You would definitely be voiding all warranties.
Old 04-30-2010, 12:39 AM   #5
Okay it sounds logical so I will keep them as a combo. Thanks
Okay thanks it sounds logical. I will buy them together. I think I will try ebay before a tile store.
Old 04-30-2010, 07:08 AM   #6
I am not sure about the thermostat, however I can tell you that research into putting a mat down prior to installing the radiant heat. If you install directly over concrete, the mat will heat the concrete first and you will lose quite a bit of heat. You can buy a self adhesive mat with primer in it at big box store.HD...
Good luck
Russ
Russman is offline   Reply With Quote
Radiant Glass Baseboard Heaters ~ Effiicient?? Paulywog HVAC 2 03-24-2009 05:34 AM
Heat source for hydronic radiant floor heating mattedfred HVAC 1 11-19-2008 06:58 PM
Radiant floor under two layers of subfloor = ok ? drh HVAC 9 11-02-2008 01:27 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
