Radiant Floor Heat - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 10:05 AM   #1
Non stop DIY'er!
Radiant floor heat
Will be installing radiant floor heat mat under tile in my bath in the next couple weeks.
Question is, when I apply the thin set over it, do I have to just build up the thin set thicker where there is no mat or heating element? To keep a level look. Like where my vanity, toliet will be. I'm guessing the answer is yes, but thought I would ask.
bajaboy1 is offline   Reply With Quote
Old 03-25-2009, 06:14 PM   #2
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
For ease of tile installation, you could just use some self leveling compound over the element.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 03-25-2009, 08:37 PM   #3
motivator
Speedball's Avatar
Self leveling being a thin mix that levels itself out?
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 03-25-2009, 09:09 PM   #4
Civil Engineer
Rewards Points: 4,954
Self levelling works well. We just installed a large electric mat under stone tile, however the mat is so thin (about 1/8 inch) that there was only a very minor issue with leveling with ordinary thinset, so we did not bother with any self leveling compound. We installed Ditramat over the mat using modified thinset, then the stone over the Ditramat using unmodified thinset (manufacturer's recommendations). The whole process was pretty straightforward. Just make sure you have a digital ohmmeter to check the wire for damage, typically the manufacturer will give you the resistance when the wire leaves the factory, and you check it to make sure you did not nick or damage the wire during the install.
Daniel Holzman is online now   Reply With Quote
Old 03-25-2009, 09:10 PM   #5
I just used the thinset to build up the area near the toilet etc
Worked fine
Old 03-28-2009, 07:20 AM   #6
Non stop DIY'er!
I guess leveling is an option. No problem with cracking, etc.? Seems a little worrysome have a thin layer of leveler, heating element, then thinset and tile on top.
You have used this method with good results?
Old 03-28-2009, 08:48 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
You misunderstand. You prime the floor, attach the element and then pour self leveler over the element instead of using thinset. Much easier most of the time. It'll leave you with a smooth cementious floor to thinset tile to.
Is the subfloor wood or concrete?
poppameth is offline   Reply With Quote
Old 03-30-2009, 09:36 AM   #8
Non stop DIY'er!
Will be wonderboard on top of wood subfloor.
So wonderboard, heating element, floor leveler, thinset, tile.
Old 03-30-2009, 12:59 PM   #9
Non stop DIY'er!
Been reading more on Ditra. Haven't laid tile for a number of years and this looks like good stuff! Lot easier than Wonderboard.
As stated before from Daniel, it goes Heating mat, modified thinset over it, Ditra, un-modified thinset, then my tile?
Sounds too easy now not dealing with Wonderboard.
Is it?
I guess it can be found at Home Depot/Lowes?
Old 03-30-2009, 01:03 PM   #10
Rewards Points: 150
Ditra does have some R value to it. So expect a little longer heat up/reheat times. If there will be any areas that already have radiant under them, there will be a timed difference that you can feel.
Old 03-30-2009, 01:10 PM   #11
Non stop DIY'er!
One other thing I just thought of, I was going to use Wonderboard right over the linolium floor, but if I go to Ditra, will I have to get down to the plywood subfloor? Can the radiant heat mat go on top of the linolium then covered with thinset, Ditra, tile? I would think not, but.....
Old 03-30-2009, 01:20 PM   #12
Rewards Points: 150
Sure! As long as the element is fully embedded in mortar, thinset or SLC it's no problem.
Old 03-30-2009, 05:03 PM   #13
REMOVE the vinyl.
R&D Tile is offline   Reply With Quote
Old 03-30-2009, 05:30 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...and use SLC.
Old 03-31-2009, 07:50 AM   #15
Non stop DIY'er!
Ok
No biggie to remove the vinyl.
So it goes:
Attach my heating element material to subfloor.
Apply SLC.
Apply Modified Thinset.
Apply Ditra.
Appy Un-modified Thinset.
Apply Tile.
Sound correct?
using forced air for radiant heating djsmith9 HVAC 22 10-30-2008 09:50 AM
Radiant heat question tpagel HVAC 4 05-21-2008 04:57 PM
Radiant flooring question tpagel Flooring 7 05-21-2008 01:41 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 01:17 PM
radiant slab vs. overhead radiant tube holedpiston HVAC 2 05-09-2007 11:59 AM
