Radiant Floor, Flooring Choices - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 10:04 AM   #1
Coatings Nerd
I have a radiant floor system in my basement, what types of flooring are best for this? After doing some research, most seem to recommend anything that doesnt restrict the heat transfer. I dont know exactly what I want, so im totally open to thoughts. Its approx 2700 ft. Im not looking to cheap out by any means. I want something that will look good, be durable, and hold up well.
Im more of a coating specialist, and have thought about doing an acid stain, with a clear gloss finish, or a built up waxed finish. My wife likes wood, but im pretty sure that would be the worst thing to do. Laminate I dont think would be much better, durability and ease of install yes, heat transfer..no. I have considered tile, but only certain areas, 2700ft may be overkill
What about commercial carpet? Or even a commercial vinyl?
What do you all think? Fire away, im open to any ideas
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 02-23-2011, 02:29 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not wise to heat wax coatings or some vinyl adhesives I wouldn't think.
The best conductor of the heat is going to be a thermal mass such as ceramic tile. Radiant heat will also heat the carpet for the most part or at least it will feel warm as you walk on it.
You also should think about what effect the heat could have on causing adhesives to off-gas and having an odor from it over time.
XXX
Old 02-23-2011, 03:43 PM   #3
Coatings Nerd
Good point, I didnt think of the heat softening the glue. Although I dont know how hot the floor will get at this point, the radiant system is installed but not hooked up.
Do you think commercial carpet would be any better?
Old 02-23-2011, 06:02 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I don't know that it would be any better than garden variety household carpet as long as it isn't a glue-down-installation version.
Let's see what Rusty Baker has to say about this, he has a few weeks of experience with carpet and flooring in general.
XXX
Old 02-23-2011, 06:16 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
I would talk to a real carpet/flooring place (not one of the big box stores). I'm not sure of this, but I've heard there is a special pad that is made for carpeting over radiant heat.
Old 03-08-2011, 08:22 AM   #6
I would recommend tiles...it transfers heat well. Check out www.radiantheatingny.com they'll have all the answers for you. they got a whole page on what to use and what's best over radiant heat system
agba8406 is offline   Reply With Quote
Old 03-08-2011, 02:50 PM   #7
woodman58's Avatar
If you wife wants wood you can do an engineered hardwood. The only restriction is that the heat at the floor can not exceed 70 degrees. At 70 degrees at floor level the room will be more than toasty.
woodman58 is offline   Reply With Quote
Old 03-09-2011, 08:21 AM   #8
Coatings Nerd
The thing that worries me about that is the expansion and contraction. The last thing I want is a huge floor with seams showing because they popped apart.
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Radiant floor heat question. ingeborgdot Remodeling 6 03-23-2010 01:05 PM
Radiant Floor Rebuild kiwegan HVAC 15 02-20-2010 04:07 PM
steam v. hot water, radiant sub-system Lor HVAC 1 06-11-2009 04:58 PM
radiant slab vs. overhead radiant tube holedpiston HVAC 2 05-09-2007 12:59 PM
