Quikrete All Purpose For Shower Pan? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 12:20 PM   #1
Quikrete all purpose for shower pan?
Hi , new to the forum. Just wondering why no one talks about using all purpose for shower pans? Anyone care to elaborate ?
Urbantileworks is offline   Reply With Quote
Old 05-06-2013, 10:58 PM   #2
Rewards Points: 918
I don't know what all purpose is, but the sand/portland mix is easier to work with than concrete with 3/4" aggregate because of the smaller aggregate size.
cleveman is offline   Reply With Quote
Old 05-07-2013, 12:36 AM   #3
Rewards Points: 626
first off it has Lime in it bad for shower pan second to make a shower pan you use 1 part Portland cement to four parts clean sand or the sand mix. you make to a humid consistancey just to were you can form a ball. using any thing else is not a good idea.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
oh'mike (05-07-2013)
Old 05-07-2013, 07:03 AM   #4
DIY staff
Rewards Points: 7,174
Do not use concrete mix for a shower pan----the fluid nature of the material leads to settling as the material sets---changing the pitch and causeing puddling---
Use deck mud like Nailbags suggested.
Old 05-07-2013, 09:39 AM   #5
The contractor I used to work for used quikrete all purpose for probably 30 yrs without one failure. I personally have done close to 50 showers this way. I'm always open to trying new things . This is just what I was taught. My old boss said the all purpose with the bigger aggregate is more structural . It has sand , Portland , sand, and small rock/stone. All I know is it makes a damn solid pan and curb.
Old 05-07-2013, 10:37 AM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Regular portland cement, sand, and water. If you can't scratch the surface after set time then its mixed wrong.
JetSwet is offline   Reply With Quote
quikrete and davis color hwidney Concrete, Stone & Masonry 4 03-12-2013 12:27 PM
Is quikrete mortar mix fine for filling holes in bricks? amodoko Concrete, Stone & Masonry 3 11-14-2012 01:16 PM
Fan Relay Wiring, Purpose of #5 terminal??? Ralph III HVAC 4 03-30-2012 10:53 PM
Quikrete vs. sakrete nikeman Concrete, Stone & Masonry 5 03-28-2012 09:47 PM
Purpose of gaps between sheets of plywood? diy888 Tiling, ceramics, marble 35 02-16-2009 12:01 PM
