Quick question regarding tiling and a SLIGHTLY unlevel floor
Hi,
If you've got a few small high spots you should grind them down. Otherwise as you said you have to raise the rest of the floor. But, if your stressing that it's only "slight", then if slight to you is about 1/16" in 12", you should be OK.
What size tiles and how wide a grout joint are you planning? Is it regular tiles with slightly curved edges or rectified?
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
