Old 02-17-2011, 10:55 PM   #1
Quick Procedure Check / Laying Bamboo
We're getting to ready to install 3-3/4" carbonized strand woven bamboo throughout the downstairs. Does this plan of action sound good?
This will all be over 23/32 osb
1. Secure subfloor in loose spots with screws
2. Plane warped edges of osb by hand
3. Prime the sob for self-leveling compound
4. Mix self leveling compound with bond agent and fill in the two dips
5. Let it all dry
6. Unpack wood and let acclimate for 72 hours
7. Check moisture level
8. Nail down floor with AquaBar B underneath
First floor, crawl space, perpendicular to the joists which are 16" on center.
Thoughts?
AndyM is offline   Reply With Quote
Old 02-17-2011, 10:58 PM   #2
Floors have been on the house for 2 weeks already but still in the box, it'll be 4 weeks when we actually get them laid.
Old 02-18-2011, 08:42 AM   #3
woodman58's Avatar
To answer #2 I would use a belt sander insead of a planer. If you hit a nail with the planer the blades will be shot.
#4 I would not use laveling compound. It will crack when a nail goes into it. Use layers uf shigles to level dips. Start with smaller peices and get bigger as you work your way out.
Example; 6", then 12", till the area is level.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
AndyM (02-21-2011)
Old 02-18-2011, 08:51 AM   #4
I use 30lb felt , 15 - then rosin if needed .
perfect feather .
Floor Doc is offline   Reply With Quote
The Following 2 Users Say Thank You to Floor Doc For This Useful Post:
AndyM (02-21-2011), tpolk (02-22-2011)
Old 02-18-2011, 05:37 PM   #5
Thanks. I've got one dip that's still squeaky after securing the floor so I'm going to brace the floor from below as well.
With the felt (it was what was available). Just keep layering it until I get the right fill? Do I need to secure it some how to the foot or just build the area up as I actually lay the floor?
Old 02-21-2011, 11:07 PM   #6
So my first attempt at doing this was a big old FAIL!
One of the dips is pretty massive (read 3 feet in radius) in the kitchen due to the joist not reaching the pier. This has been fixed.
I tried to cut the roofing felt into 6 inch squares, then 12 inch squares and then 18 inch squares and layered them on top of each other. Problem is with the width of the dip, I had a hard time making it close to smooth.
Thoughts or keep hammering away until it works?
Old 02-21-2011, 11:30 PM   #7
Still going...
ChrisDIY's Avatar
Do you have a six foot level? Span the dip then measure deepest point divide by thickness of sheets. I'm guessing you need round or dip shaped pieces. That's how I'd use this advice. Hope they will support my suggestion.
Also six foot diameter? That'd not a dip that's sag. Anyone agree?
Sent from my Samsung Vibrant using Android DIY Chatroom
--Chris the DIY Guy
Still going, on Ibuprofen...
ChrisDIY is offline   Reply With Quote
Old 02-22-2011, 07:41 AM   #8
I ran the six foot level across the sag for a maximum depth of 1/8th.
So 4 layers of the felt at .8mm thick. I think that's the thickness of the felt. Will check tonight.
Just run the level across and build up until it touches?
Old 02-22-2011, 10:41 AM   #9
Floor has to be flat 1/8" in 6' or 3/16" in 10'
To use, or not to use Bamboo... dmcandy Flooring 10 08-23-2012 01:19 PM
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 10 12-17-2009 04:34 AM
Laying 5/8" Bamboo Flooring kirkeric Flooring 7 08-13-2007 03:36 PM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-20-2007 12:11 AM
