Quick Help On Hardwood Flooring Please - Flooring - DIY Chatroom Home Improvement Forum
Old 07-31-2006, 10:43 AM   #1
Quick Help on Hardwood Flooring Please
Hey everyone, i have a problem. The deal is this, I am selling my house and when i was moving out i needed to get a huge hutch out of our dining room. I put blankets under the front and back and slid it out of the house. This was the way we got it in with no problems. This time it put about a half inch scrath across the floor. It looks as if it is only the finish that is scratched, definatly not the wood. Is there any help on how i could fix this myself. Doing it right but keeping it as cheap as possible. Any help would be great, thanks.
DeanHetzel
DeanHetzel is offline   Reply With Quote
Old 07-31-2006, 12:53 PM   #2
If the wood is not damaged then just lightly sand and put on some poly (finish) to match. I think that they sell "touch-up" pens for this purpose.
redline is offline   Reply With Quote
Old 07-31-2006, 01:28 PM   #3
Thanks, i will check out the depot and see what i can find. Thanks again!
DeanHetzel
Old 08-02-2006, 08:03 AM   #4
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
If it is lacquer (which isn't used much for flooring any more so depends on the age of the floor) you might consider a light 220 grit sanding of the infected boards (the whole board) and get some brushing lacquer and redo each board. If the floor is poly, don't do this with lacquer as I don't believe you can put lacquer on poly, but I think you can put poly on lacquer.
This also depends on how the floor looks. Does it look like one big sheet of glass or can you see transitions from board to board?
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Hardwood Flooring in Basement bcrwfan Flooring 1 02-12-2007 12:33 PM
hARDWOOD FLOORING CHERRYCAKE3 Flooring 1 03-08-2006 02:44 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 05:45 PM
