Questions About Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2010, 09:13 PM   #1
Questions about subfloor
Hi, everyone!
I have some questions about subfloor installation:
1) Every reference I have seen says "subfloor must cover at least two spans." If a 16" panel is supported only by two joists 16" on center, is that two spans (two joist spans), or one span (one gap span)?
1a) If a panel must touch three joists, does it count if one of the three joists is not the full width? Most of my joists are 16" O.C., but the last joist is just 11" to the wall. Can I use a piece of subfloor that spans the 26" instead of 32"?
2) The recommended installation method for subfloor is to use adhesive on the joists. I am using steel framing. Do I ignore this, use the same adhesive, or is there a special adhesive?
Thanks!
-cwm9
cwm9 is offline   Reply With Quote
Old 03-03-2010, 06:06 AM   #2
I am a bit confused by your questions. Perhaps a better description of what you are doing would help. Is this an addition?? Steel joists????
Old 03-03-2010, 11:40 AM   #3
No, this is new house construction using light guage steel.
Old 03-03-2010, 02:22 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 340
Hi 9,
1. The requirement is that any section of subfloor lay on 2 spans, which means 3 joists. Can't have 2 spans with only 2 joists. The reason of course is that there will be a large amount of curvature in the panel without a center support.
1a. Yes, that's fine. You still have 3 joists and the span is less so it's stronger. Just make sure the plywood subfloor is laid with the face grain across the joists as always. This sounds like the subfloor will be cut up or repaired. If so, you may need to install an underlayment. What are you installing as the finished covering?
2. Steel joists?
Jaz
Old 03-05-2010, 09:10 PM   #5
Originally Posted by JazMan View Post
Hi 9,
2. Steel joists?
Jaz
Yes. I'm not sure why this is surprising? Example: http://blueskyhomes.files.wordpress....3/dsc_0016.jpg
Wood flooring subfloor questions -- picture ID sportinwla Flooring 3 01-02-2010 06:48 PM
So many questions - tub installation, floor tiles, subfloor... chrispy35 Kitchen & Bath Remodeling 4 11-10-2009 11:18 PM
Subfloor and Underlayment Questions JulieZ Tiling, ceramics, marble 14 06-23-2009 08:04 AM
Kitchen subfloor questions tishimself Tiling, ceramics, marble 7 12-09-2008 09:16 AM
subfloor questions twofortripping Flooring 8 11-08-2008 08:07 PM
