Questions About Installing Bullnose Baseboard Tiles For Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 08:42 PM   #1
Questions about installing bullnose baseboard tiles for bathroom
1. Which notch and shape trowel should I use? I'm assuming a 1/4" v-notch. The bullnose tile is 3" high and approximately a 1/3" thick.
2. The floor has 3/16" groutlines. I want to use the same width for the groutline between the bullnose and floor, and then fill it with grout. I'm reading that many people recommend making the width smaller and the filling it with chalk instead because this is a bathroom. Is that effectively necessary?
Swazzle is offline   Reply With Quote
Old 09-23-2010, 09:10 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
Hi Swazzie,
1. Makes no dif. use a butter knife if you want.
2. I'd go an 1/8" max, but whatever you want is fine if you think it'l look ok. Usually wider joints are for rustic tiles. So, I say 1/8" or less, maybe use pieces of the cardboard the tiles came in. It's best to use a matching caulk at that joint cuz grout is likely to crack.
Jaz
Old 09-23-2010, 11:14 PM   #3
Brilliant, thanks Jaz. If I go with 1/8", should I used sanded or unsanded grout? This is my first time doing this.
questions on self stick tiles NoExperience Flooring 6 08-20-2008 12:04 AM
Installing window questions bakerhouse Remodeling 4 05-18-2008 01:22 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 05:06 PM
couple questions about installing phone jacks joeyboy Electrical 31 10-09-2007 02:26 PM
questions about installing television antenna darsunt Home Theater 2 05-07-2007 01:16 PM
