Questions About Floor Leveling. SLC Or Roofing Material? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 12:45 PM   #1
Questions about floor leveling. SLC or roofing material?
Hi, this if my first post here, but I've been reading a lot of posts, and still have a few quesitons.
I have Teragren solid strand bamboo flooring that I'm about to install. It's 3/8" thick and 3 3/4" wide and will be nailed down with a cleat. My 5/8" plywood subfloor has a few high and low spots that I'm trying to smooth out. I sanded about 1/8" off the high spots with a belt sander, and am trying to decide how much more I should sand off, and then which method I should use to fill in the low spots. My floor is structurally sound, and this is the second floor, so there's no access to the joists. The worst area is two high joists about 5 or 6 feet apart with a low spot in between. It's about 5/16" from the high spot to the low spot. There are several other high and low spots as well, but they're not as bad.
My questions are how much more can I sand off of the high spots, and should I use shingles/felt paper or a self leveling compound to fill in the lows? And if I use a SLC, which one is best and can you nail through it?
Thanks a lot!!
-Tim
Timbro is offline   Reply With Quote
Old 02-14-2010, 01:41 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope! No rigid fillers can be used for that reason.
Use the felt product and don't get too anal about it, it will work out OK.
XXX
Old 02-18-2010, 11:32 AM   #3
OK, thanks Bud! Thanks for the tip about not being anal too, cuz I have a tendency to overthink things!
Old 02-18-2010, 07:15 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It's easy to get carried away marathon-thinking about such things. I understand where you are coming from, it happens a lot on all of these (How To) forums. Too much information...a lot of it bad information.
XXX
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
re: roofing material questions gramps416 Roofing/Siding 6 06-30-2009 03:42 PM
EPDM roofing questions zantar Roofing/Siding 4 05-03-2009 07:10 PM
Roll roofing material RedDawg454 Roofing/Siding 8 05-03-2007 06:52 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
