Questions About Carpet Pad Tools - Flooring - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 10:41 PM   #1
Rewards Points: 682
Questions about carpet pad tools
I understand you should use a hammer stapler to fasten down carpet padding. Is this a specialty carpet tool I should rent, or do they sell them at home depot? How much should I spend if I buy one? And do I have to worry about the size of staples? The old staples I am pulling out look small.
Also should I bother to get a carpet knife? All the carpet installer I've seen just use utility knives.
darsunt is offline   Reply With Quote
Old 02-02-2012, 10:53 PM   #2
Rewards Points: 682
I will probably be installing carpet maybe twice a year
Old 02-02-2012, 11:08 PM   #3
Rewards Points: 582
t
should be able to buy hammer tacker most places and I like to use a carpet knife...alot just use utility knife which will work.. prices vary I think mine was around 24.00 which i use for other purposes good investment...
Old 02-03-2012, 12:58 AM   #4
Rewards Points: 682
Staples size is standard? Does it matter? Like I said, the old pad staples I am pulling out look rather small.
Hallway Carpet to Wood Conversion - Some Beginner Questions LAugs1 Flooring 17 07-13-2011 09:56 AM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Flooring for basement with water issues Leoskee Flooring 27 08-27-2008 08:49 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
