Question On Preparing Surface For Ceramic Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 07-19-2008, 11:20 PM   #1
Question
Question on preparing surface for Ceramic Tile
I'm preparing a plywood floor for ceramic tile. The floor was previously covered with tile, but I've removed the tile & backerboard . I am in the process of scraping the previous thinset up. It's not coming off very easily or cleanly. How clean does the plywood surface have to be before I lay another layer of thinset & new backerboard on it?
Last edited by AtlanticWBConst.; 07-20-2008 at 06:33 AM. Reason: Discussions Merged: Same topic
Rferret is offline   Reply With Quote
Old 07-20-2008, 12:58 AM   #2
Be green & save green
Needs to be fairly clean but more importantly very even for the new thinset to adhere to the plywood.
You can always apply more thinset before the backer board and make the plywood more level that way.
You can also sand off the thinset
mgsproperties is offline   Reply With Quote
Old 07-20-2008, 06:16 AM   #3
HomeAdditionPlus.com
Rewards Points: 29
First, the subfloor should be free of any loose material. If it is not level use a leveling agent. Spread the leveling agent over the floor surface to smooth out any irregularities in the floor.
Last edited by AtlanticWBConst.; 07-20-2008 at 01:13 PM. Reason: Site Rules Violation: Link Removed from Signature
mjdonovan is offline   Reply With Quote
Old 07-20-2008, 12:08 PM   #4
Get out of the box!
Rewards Points: 260
Step out of the dark ages and into the light = Light work as well.
Remove the old thinset.
Check you floor for deflection. if you are with perimeters use Ditra.
Save your back and your time, the days of Backerboards are limited.
Level the floor first as MJ says but use Ditra this time.The floor will never fail.
View Ditra specs here:
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
Last edited by Ron The Plumber; 07-20-2008 at 12:44 PM. Reason: Advertising not allowed with out prior consent from Admin on this site.
26yrsinflooring is offline   Reply With Quote
Tile installation question pjpjpjpj Carpentry 7 09-21-2008 11:29 AM
interior wood trim, surface preparation question copacetic Painting 3 04-25-2008 07:52 PM
Tile laying question Profane Flooring 12 01-25-2008 10:28 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
HELP! Question About Lousy Tile Setting Job... EricW Flooring 10 09-13-2006 07:02 PM
