Question On Installing Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 07:37 PM   #1
Question on installing tile
I am remodeling my bathroom. I had the vinyl flooring that were 12" squares they just glued onto the wood sub floor. When removing the vinyl squares it left a tacky glue but its not visible. When u walk on the subfloor, your shoes will stick to it a bit.
My question is can I tile over top of the wood sub floor as it is? If not, what is the best remedy for this situation?
pwarther is offline   Reply With Quote
Old 12-08-2009, 11:09 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Most people think the wood under the vinyl is the subfloor. In most cases it's the underlayment which is probably 1/4" or less thick. If it is a thin sheet of ply or OSB or ?, you need to removed that too. You can then evaluate the subfloor, re fasten as necessary and add more ply if needed or install a tile backer board, (cement board) or a membrane such as Ditra or one from Noble.
Back to your original question about tiling right over wood. Not a good method at all, esp. in a room that may get damp.
Jaz
JazMan is online now   Reply With Quote
Old 03-20-2011, 05:02 PM   #3
Get some concrete board and tap that down n then do the tiling!
IceT is offline   Reply With Quote
Old 03-20-2011, 05:17 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
[quote=IceT;613339]Get some concrete board and tap that down n then do the tiling![/quote
No !
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
tile and toilet flange question rbaggett Plumbing 2 11-13-2008 05:43 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
Floor and wall tile question irlizard Flooring 21 07-20-2006 02:35 PM
