Question About Install Allure Flooring System Over Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 04:32 PM   #1
Question about install Allure flooring system over linoleum
A friend of the family has asked me to install about 400 sqaure feet of the Home Depot Allure vinyl plank flooring system in a large room that has a concrete slab that is currently covered by linoleum. The linoleum is in very good shape and extremely well bonded over 99 percent of its surface. There are just a couple of areas that are lifting by door thresholds. These areas also have some small tears from the doors hitting them.
What is the best way to repair the lifted areas before laying the Allure? I was thinking about cutting the linoleum back until I get to material that is adhered solidly and then fill the void I created with thinset. Whadya think? All advice is greatly appreciated. Thanks!
dgeorge is offline   Reply With Quote
Old 01-06-2011, 08:15 PM   #2
Rewards Points: 1,562
According to the instructions that should have been in the box: "9. If any individual allure plank seams or edges should release from one another,
it usually can be corrected by applying warm air from a hair dryer or paint gun
for 5 to 10 seconds from a distance of 8. Then step on (or roll) the edges and
maintain pressure until the re-adhesion is effected. If the problem persists, contact
your Home Depot representative or Halstead’s Consumer Hot Line at
1-866-THD-TILE ext 6 care & maintenance."
Have you tried this and it failed? If so, have you tried the phone #?
bob22 is online now   Reply With Quote
Old 01-06-2011, 08:47 PM   #3
Allure over linoleum
I haven't installed the Allure yet. I may have not been clear in my post. I a prepping the linoleim that exists on the floor now. I have a few pulled spots in the linoleum. I planned to cut them off, fill the voids with thinset, then lay the Allure over top to of that. just wondering it this would be ok. Thanks!
Old 01-07-2011, 09:29 AM   #4
Sorry; my mistake!
Old 01-07-2011, 12:38 PM   #5
Originally Posted by bob22 View Post
Sorry; my mistake!
No problem at all!
Anyone else run into this situation? how did you patch the area? Thanks!~
Old 01-07-2011, 12:46 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
I would use a cementious based floor fill.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-07-2011, 12:58 PM   #7
Gotcha. Thanks!
Old 01-08-2011, 08:20 AM   #8
Just cut off the nicks and then do what Rusty recommends. Floating floor could be on top of "lifted piece, depending how pliable the original sheet is. You can either glue and roll the old stuff first or cut it all off and then use filler.. If it was lifting because of wetness under it (talking about the old stuff), you must solve this problem first. Like - is it problem with your underlayment?
You say that some nicks were caused by the door - make sure that the new layer of the Allure will be safely clearing the bottom of the door! If the door sweep will be dragging over the Allure's surface, any grit (sand, etc.) present will mark the allure surface over time.
stary kozel is offline   Reply With Quote
Old 01-08-2011, 03:40 PM   #9
Thanks for the additional advice. When I say the old stuff is old, its really old...like 30+ years. I think it peeled because the adhesive has simply dried out and cracked, allowing the doors to hit it when they open. I cut a piece off already and the doors clear with plenty of space. Worse comes to worse, I'll pop the door off and trim them with my circular saw. Thanks folks!
I'll try to get some before and after pics if possible!
Tags
allure over linoleum
Allure flooring and prep work bstreyle Flooring 1 04-12-2010 04:43 PM
Allure Flooring - Quarter Round Molding PatsyK9 Flooring 4 04-10-2010 09:04 PM
Hydronic Towel warmer install question bigbluedude HVAC 5 02-13-2010 08:02 AM
Install allure in fl lanai GJG Flooring 6 11-12-2009 10:32 AM
Window install question reguarding tyvek marlinpuppy Building & Construction 2 02-12-2009 12:56 PM
