Old 01-20-2009, 11:14 PM   #1
Default Question About Grout Line Size
This weekend I was in a restaurant that a ceramic tile floor laid with 16" tiles. The grout lines were minimal- to my calibrated eyeball they looked like about 1/16th of an inch. It occurred to me that this would be a good idea for minimizing the "dirt traps" that larger grout lines can create and for maximizing the evenness of the floor, and I liked the look.
Are there any "rules" regarding the size of a grout line? Is it a matter of design taste, or are there some real guidelines that I should consider?
Thanks in advance.
Greytguy is offline   Reply With Quote
Old 01-21-2009, 03:44 AM   #2
I believe it is for the most part what you think looks the best. The only rule i have ever read is that gaps less than 1/8" can have unsanded grout and anything over 1/8" has to have sanded grout.
ponch37300 is offline   Reply With Quote
Old 01-21-2009, 08:30 AM   #3
Tileman-Manufacturers rep
What Ponch said is true, but you have to have a good quality tile to be able to set the tiles closer than 1/8" apart in the first place. Most cheaper tiles can not be installed close because they are not a consistent size and/or are rectangular instead of square. Some are a chore to install under 1/4"
The tiles you see with tight joints are almost always "rectified" tiles, not regular ones.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
Old 01-21-2009, 12:59 PM   #4
Super Moderator
Floorwizard's Avatar
Jaz Man is correct. The tiles need to be rectified or perfectly square. Like natural stone usually is or some porcelain.
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 01-21-2009, 01:16 PM   #5
Extreme DIY Homeowner
Scuba_Dave's Avatar
My shower tiles were 4". I used the built in edge ridges on the tiles as the determining factor in grout size
For the floor I went with an almost white tile
I used large grout lines & black grout to make the tiles stand out
In my hallway I went with 1/8" lines - 12" square tiles
For another bathroom I again went with larger grout lines as the 12" tiles had "scalloped" edges & it looked better
Scuba_Dave is online now   Reply With Quote
Old 01-21-2009, 01:34 PM   #6
Jaz
I would never have known that unless I asked on this forum. I assume that I would have to specify "rectified" tile when purchasing and that they are more expensive than standard tile? (Let me guess: the help at a "big box" home store would give me a blank stare...)
Thanks!
Old 01-21-2009, 02:05 PM   #7
Super Moderator
You may get a blank stare. Unfortunately they are not as knowledgable as a tile store employee may be. Just make sure when they answer they are confident. I see no reason why they would not carry a rectified tile...just need to make sure. Usually a heavy glaze would be a sign of non-rectified...the glaze (if dripped over the edges) would make it out of square...it would have a clean cut on all 4 sides to be rectified...usually.
Time to ride again!
More On This Topic
Tile floors make great surfaces in basement settings. Whatever type tile you chose, you can lay your own tile floor and easily keep it looking good. One of the processes to keeping a good-looking tile floor is sealing the grout. It's an easy step to do... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment, I am going to show you how to clean the grout. In our last segment, I used an acrylic grout versus a sandy or a non sandy grout. Typically we would use a sponge... Read More »
A grouting float is a flat, rectangular piece of metal with a handle on the top that is used to apply grout to a tiled floor. The float is used during one of the final stages of the tiling process and is relatively simple to use. Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and in this segment, I am going to show you how to apply a grout and talk about grout a little bit. There are three separate kinds of grout. There is a sandy grout, non-sandy grout... Read More »
Today we’re going to be re-grouting the tile around the window in the bathtub. Once your grout has set out for about five to eight minutes, you get yourself a grout trowel, which is just spongy so you can apply the grout. And you just scoop some... Read More »
It's true. Size matters. - Carpeting Question kcrossley2 Flooring 4 11-19-2008 01:32 PM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 02:23 PM
Grout question poolecw Flooring 11 10-29-2008 09:32 PM
electric line and gas line couch potatoe Electrical 17 10-01-2008 12:43 AM
Wire size for distance Question fburke Electrical 4 07-28-2007 11:29 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
