Old 01-24-2012, 10:05 PM   #1
Question about cork flooring in master bath
My wife and I are going to install cork tiles in our master back (glue down). The cork is 4mm thick. My question is will the contact cement adhere well to the existing vinyl floor? Let me explain. I want this floor to be as waterproof as possible (of course). The reason installing a cork floor in a bathroom is a bad idea is most people install the floating type with the fiberboard center. If I pull up the vinyl I will have to put a cement base product onto the existing subfloor prior to the tiles to make it water resistant. My thought was if I sand the vinyl floor with fine sandpaper and clean the floor with acetone this should give me a good surface to adhere the cement to with no dirt buildup on the vinyl. Has anyone out there tried this?
HooterVol is offline   Reply With Quote
Old 01-25-2012, 06:33 PM   #2
I have heard people of doing this but I do have some concerns with it. By having a solid backing (example cement board) you will have a smooth surface that will not lift. My concern with the vinyl is that if it starts lifting and it is under the cork, the floor will start lifting as well. Also and bumps in the vinyl will eventually show up as bump in the cork. The cork really needs to be glued to a smooth surface. Have you thought about screwing cement board on top of the vinyl? This way you wont have to tear it out. If you do this, double check what the extra thickness will do at the doorways.
Hope this helps.
John
APC Cork is offline   Reply With Quote
Old 01-25-2012, 07:02 PM   #3
sdsester's Avatar
Any sort of tile glued to existing vinyl, in a wet area, is going to float around on you eventually. The adhesion just gives way eventually.
sdsester is offline   Reply With Quote
Old 01-25-2012, 07:49 PM   #4
Pro Flooring Installer
rusty baker's Avatar
It is never, ever a good idea to sand vinyl.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Tags
cork, cork flooring
Master Bath Remodel - Need Advice meth Building & Construction 8 12-07-2010 06:31 PM
Tiny Master Bath Remodel??? Orchdirector1 Kitchen & Bath Remodeling 14 10-30-2010 08:24 PM
Strange Master Bath 'Odor' MeatballCB Plumbing 12 09-17-2010 09:05 AM
Would it be acceptable to combine using travertine and porcelain in a master bath to save on money? ikendawn Kitchen & Bath Remodeling 0 07-13-2010 09:42 AM
Master Bath wiring help BimmerRacer Electrical 2 08-17-2009 11:27 AM
