Old 01-06-2007, 11:39 AM   #1
Quarter round on round outside corners
I have installed Harmonics Brazillian Cherry Laminate Flooring and I am now ready to install the quarter round.
I have several ROUND OUTSIDE CORNERS.
I was planning on cutting several small pieces to go around each corner. However, after looking closer I believe it will look sloppy.
I could not find any premade.
Thank you.
biyoba is offline   Reply With Quote
Old 01-06-2007, 07:11 PM   #2
Home Improvement Guy
ron schenker's Avatar
You could buy some flexible Q.round at H. Depot
ron schenker is offline   Reply With Quote
Old 01-06-2007, 11:08 PM   #3
remodeling pro
How big are the radaii? You can make curved quarter round pretty easy with a router and a round over bit, and either a bandsaw or good jig saw with a quality blade, like the Bosch. The curved pieces will go across some "short grain" in the wood, so they are fragile to nail. I suggest you use construction adhesive to apply them. I'm thinking fairly small radius here. If they are large, you might be able to carefully bend stock around them. Help by heating the face of the moulding with a heat gun or even a hair dryer . This will help the fibers stretch instead of snapping.
troubleseeker is offline   Reply With Quote
Old 01-07-2007, 10:40 AM   #4
Darylh's Avatar
Making your own sounds like a good idea to me or you could bevel the corners
Darylh is offline   Reply With Quote
Old 01-07-2007, 08:39 PM   #5
Tileguy
Bud Cline's Avatar
What's the radii and what material are you using for the 1/4round?
small quarter round moulding mf915 Flooring 11 09-30-2009 01:14 AM
Quarter round in basement? xray328 Carpentry 5 07-24-2007 07:08 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
Laminate Flooring Quarter Round Cuts no3jack Flooring 1 12-11-2006 09:30 PM
Quarter round and baseboard justtired Flooring 1 09-30-2006 05:39 PM
