-   -   Quarter round and mold issues with laminate floor (http://www.diychatroom.com/f5/quarter-round-mold-issues-laminate-floor-158195/)
gwill 09-27-2012 06:58 PM
A couple quick questions. I'm about to install a laminate floor with padding attached on a basement concrete sub floor. No issues with water in the basement. But I'm worried about putting down a moisture barrier, which will prohibit the concrete from breathing, or so I figure, and could lead to a layer of mold between the concrete and plastic sheet. Should I clean the floor with bleach? Or use an underlay that they sell at Home Depot that's supposed to enable air to flow between the sheet and concrete? (Roberts AirGuard 100 sq. ft., 3.34 ft. x 30 ft. X .25 in. thick, Premium 3-in-1 Underlayment for Laminate Floors) Any other strategies?
And two, I was planning on the leaving the base boards on and using quarter round to cover the quarter-inch gap. Okay to do that, or do I need to take the base boards off?
of2012 09-27-2012 07:58 PM
gwill,
I would not use an underlayment (other than a plastic film) with a product that has an attached pad. This will cause too much joint deflection.
You can leave the baseboard on and add a quarter round.
Best,
gwill 09-27-2012 08:03 PM
thanks. any ideas about how to prevent a potential mold issue with the plastic underlay and concrete floor? or is that not a legitimate concern?
DannyT 09-27-2012 08:44 PM
i would follow the manufacturers installation instructions on what to put under the floor. if you have small base it will look even smaller after the height of the laminate and the shoe molding will make it look a lot shorter then it really is.
gwill 09-27-2012 08:52 PM
Hi Danny,
Thanks. The plastic moisture barrier is the recommendation. Any reason I should be worried about mold? I cant help but think the floor won't be able to breath. Anyone have any ideas? Or can tell me if my concerns are misplaced?
