Old 07-07-2010, 10:23 AM   #1
Unhappy
Putting down engineered wood flooring - staple lumps
I am putting down engineered wood flooring. It is single planks. They are using the staple down method. I am concerend because when the sun shines through the window, I can see every place a staple was used because there is a small lump. Is this common with this type of intallation of this product?
mrsbtate is offline   Reply With Quote
Old 07-07-2010, 10:33 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I'd guess it's a quality issue. I've seen some very thin, poorly made "flooring" that would easily do what you describe.
Could be any number of other reasons, that's just my guess.
The guys here may have different opinions/possible fixes for you as well, so check back.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-07-2010, 04:16 PM   #3
Handyman
I have never seen a floor with instructions to 'staple' into the face of the board. Am I reading this wrong? Do you have any pics? Are you sure it is engineered and not hardwood? Staples or cleats are used to install hardwood flooring but, again, not through the face but through the t&g joints. A floor nailer is required though.
canadaclub is offline   Reply With Quote
Old 07-11-2010, 03:35 AM   #4
probly too big of staples ,or air pressure is wrong for the staple gun . what thickness of flooring ?Try reading the directions
I assume you mean they are blind stapleing .
tacomahardwoodfloors.com
tacomahardwood. is offline   Reply With Quote
Old 07-11-2010, 06:56 AM   #5
Handyman
What is that Tacoma?
Old 07-11-2010, 01:45 PM   #6
Means you staple the wood on the top of the toungue with a 45 degree angle staple gun ,when you put the next piece of wood in place the groove side will hide the staples . If you don't understand what blind nailing is then have someone show you ,Its very simple tacomahardwoodfloors.com
Old 07-11-2010, 08:20 PM   #7
Handyman
Thanks Tacoma..nice advice. Only blind nailed on deck skirts but I get you're drift.
engineered flooring chevylover1988 Flooring 39 11-04-2010 11:21 PM
Carpentry: PT Plywood subfloor - Putting flooring on it? Jeffries Flooring 7 06-21-2010 11:02 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
Glue and staple engineered wood on stair treads? cej22 Flooring 1 09-23-2009 11:13 AM
Foam underlayment for engineered wood tired_and_crazy Flooring 2 06-12-2009 02:27 PM
