-   -   Putting down engineered wood flooring - staple lumps (http://www.diychatroom.com/f5/putting-down-engineered-wood-flooring-staple-lumps-75608/)
mrsbtate 07-07-2010 10:23 AM
I am putting down engineered wood flooring. It is single planks. They are using the staple down method. I am concerend because when the sun shines through the window, I can see every place a staple was used because there is a small lump. Is this common with this type of intallation of this product?
DangerMouse 07-07-2010 10:33 AM
Hi and welcome to the forum.
I'd guess it's a quality issue. I've seen some very thin, poorly made "flooring" that would easily do what you describe.
Could be any number of other reasons, that's just my guess.
The guys here may have different opinions/possible fixes for you as well, so check back.
DM
canadaclub 07-07-2010 04:16 PM
I have never seen a floor with instructions to 'staple' into the face of the board. Am I reading this wrong? Do you have any pics? Are you sure it is engineered and not hardwood? Staples or cleats are used to install hardwood flooring but, again, not through the face but through the t&g joints. A floor nailer is required though.
tacomahardwood. 07-11-2010 03:35 AM
probly too big of staples ,or air pressure is wrong for the staple gun . what thickness of flooring ?Try reading the directions
I assume you mean they are blind stapleing .
tacomahardwoodfloors.com
canadaclub 07-11-2010 06:56 AM
What is that Tacoma?
tacomahardwood. 07-11-2010 01:45 PM
Blind staple
Means you staple the wood on the top of the toungue with a 45 degree angle staple gun ,when you put the next piece of wood in place the groove side will hide the staples . If you don't understand what blind nailing is then have someone show you ,Its very simple tacomahardwoodfloors.com
canadaclub 07-11-2010 08:20 PM
Thanks Tacoma..nice advice. Only blind nailed on deck skirts but I get you're drift.
