Old 03-25-2009, 02:59 PM   #1
putting down ceramic tile over old linoleum adhesive
i have a house thats 4 years old and im taking up the linoleum can the new tile be put down over the top of the glue?
waltdisney is offline   Reply With Quote
Old 03-25-2009, 03:16 PM   #2
Super Moderator
Floorwizard's Avatar
Glue may be the least of your problems.
What is the substrate?
Time to ride again!
Floorwizard is offline   Reply With Quote
Old 03-26-2009, 08:11 PM   #3
thanks for responding do you mean what the floor is? if so it's a concrete slab
Old 03-27-2009, 12:41 PM   #4
Super Moderator
Then you need an anti fracture membrane first.
Check a product called Ditra and see what their recommendation is for floor prep.
Time to ride again!
More On This Topic
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and in this segment, I am going to show you how to apply a grout and talk about grout a little bit. There are three separate kinds of grout. There is a sandy grout, non-sandy grout... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment, I am going to show you how to clean the grout. In our last segment, I used an acrylic grout versus a sandy or a non sandy grout. Typically we would use a sponge... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment, I am going to show you how the apply the adhesive for your new floor installation in your basement. The first thing I want to do is because I am working in a small... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and now I am going to show you how to put the material back into the adhesive. You are going to start up by rolling the material slowly back into the adhesive. Making sure to try... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. Now in this segment, I am going to be showing you how to set your tile and applying the mud to the floor. We would let our mud slack off after mixing it for 10 minutes. I have a... Read More »
Can I ceramic tile over linoleum? havetime_4fun Flooring 16 04-30-2009 11:08 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Ceramic tile on slab - install over adhesive left from vinyl tiles? softwareguy Flooring 1 08-23-2008 11:48 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 09:38 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
