Putting Down Backer Board...Do I Need To Add A SLC Or Can I Just Put It Down? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-03-2016, 06:25 AM   #1
Rewards Points: 4
Question
Putting Down Backer Board...Do I need to add a SLC or can I just put it down?
I am remodeling my kitchen. I pulled up the tile, which was down, when I bought the house. The person who installed it, placed the tile directly on the plywood subfloor. I am going to be putting down backer board, so I can put vinyl down.
Do I need to use a SLC to level the floor before I put the backer board down? Do I need to use SLC after I put the backer board down? Or do I even need to use SLC, because I am putting vinyl over the backer board?
rcjr is offline   Reply With Quote
Old 03-03-2016, 06:57 AM   #2
Rewards Points: 13,300
Did you scrape off all the old thin set?
What condition is the plywood in?
Not sure what you mean by "backer board", should be laying subfloor rated plywood and filling any gaps and flaws so you have a flat surface.
Pictures are your friend here.
Old 03-03-2016, 08:15 AM   #3
DIY staff
Rewards Points: 7,174
More info, Please---for sheet goods, a layer of self leveling compound (without any special backer board) will give you a fine surface.
Old 03-04-2016, 02:08 AM   #4
Rewards Points: 4
Sorry, I am new to this. I have a plywood subfloor, which is in good condition. I have got all of the old thin set off of the plywood (subfloor). By backer board, I am talking about a cement flooring, which I will be putting over my plywood subfloor.
I will try to get pictures, as soon as I am able. Any help is appreciated!
Tags
backer board , flooring , leveling floor , slc
Raised spot in backer board nikkiscott Flooring 1 01-12-2016 08:36 PM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
Hardie backer board textured with thin set wildwort Tiling, ceramics, marble 14 11-21-2011 11:01 AM
From these Pics what do you think is the correct way for the backer board K.M.G Plumbing 17 12-01-2009 11:11 AM
Can I put a vinyl tub surround on DensShield backer board ioniz Building & Construction 5 07-04-2009 06:31 PM
