Old 06-14-2008, 01:42 AM   #1
put carpet on laminate >
Hi,
B'cuz of small kidz we decided to put carpet in our living room, rug could work but still leaves some spaces open + it's not so soft like carpet with underlay. So...
Anybody think we can put carpet wall to wall somehow and save our laminate for later ? I don't know whether it glued or not, so didn't try to take it out + we have very nice baseboard with stop.
I've checked carpet strips, nails goes each 6" or so, so it's really killer for floor. And carpet pros don't suggest anything else: carpet need to be stretched and hang on strips that nailed to the floor. + underlay should be stapled also.
Probably we can skip every other nail in strip and later fix those holes in laminate, anybody has experience how good this method, can you see anything after repair.
Or anybody can suggest anything else, how make carpet softer and save laminate.
Tx all
dai
dainova is offline   Reply With Quote
Old 06-14-2008, 10:56 AM   #2
Building codes guy, Mod
thekctermite's Avatar
In order to conventionally install carpet, it must be attached to tack strips and stretched under tension to those tack strips. The tack strips need to be secured to the floor, and you have a floating laminate floor. I think that could really do damage to the laminate you're trying to save.
Have you considered carpet squares? You can get larger squares or smaller squares. They're not terribly expensive, and if someone spills something you can just replace a square or two. You could use some carpet tape to secure them to the laminate. The tape adhesive residue would come up later with some adhesive remover or WD40.
thekctermite is offline   Reply With Quote
Old 06-14-2008, 11:51 AM   #3
Tileguy
Hi,
Tx all
dai
Flooring forums are my main source of entertainment. Just when you think you've heard it all.........look what pops up.
Old 06-15-2008, 08:49 PM   #4
Remodeler
MinConst's Avatar
dai,
Putting down tackless through your Lam floor will fasten it to the sub floor below and it will no longer be a floating floor. If it is not a glue down you will have trouble in short order. There should be a space between the floor and the wall to allow it to float. Putting nails through it eliminates the purpose of the float. Expansion and contraction is the reason for the needed movement.
The only thing that comes to mind is double face tape. The carpet will lay flat after awhile and may pucker in spots but do not use tackless.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
More On This Topic
How to Install Carpet
How to Install Carpet by Expert Village
This is Kevin with Expert Village we are going to one day bathroom remodel. At the end of the process when we got the carpet in place there where existing nail strips all around the outside of the room and I simply went around and step on the carpet so... Read More »
Give a finished look to your new flooring by nailing a shoe, or quarter-round, to your base molding. By installing the shoe over the flooring, you will hide all uneven edges in the flooring at the perimeter of the room. Also, in older homes, you can... Read More »
Hi! I am Tim Eaton on behalf of Expert Village. We are here doing the shoe molding demonstration and we are going to get ready to nail it. So when you are nailing you always want to start at one end and the other. Do not start in the middle and make sure... Read More »
How to Paint Base Board
How to Paint Base Board by Expert Village
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Now, I want to talk a little bit about painting the baseboards on an interior paint job. Now the baseboards are the very last thing that we paint... Read More »
Hi! This is Diana with Expert Village.com and today we are going to be steam cleaning your carpet at home with a rental machine and one of the things that you have to do first is vacuum your carpet before you steam clean. Now we’ve moved the... Read More »
Laminate Over Carpet JoeyJet Flooring 8 12-13-2007 03:12 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet vs Laminate and Vinyl vs Ceramic Kaminberry Flooring 5 02-26-2007 08:03 PM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
