Old 05-30-2010, 03:10 PM   #1
Apprentice
UpComingBuilder's Avatar
Lightbulb
Purgo Flooring on top of slab w/ radiant floor heat
I am going to install a pergo floor very soon. Its a 1 floor ranch sitting on a slab with radiant heated floors.
I have two questions. The pergo flooring comes with a subfloor attached to it. Like a soft underlay so you don't need to buy the rolls.
I was wondering if thats takes a different blade than a regular carbide blade because of the underlay it comes with??
And there are 4 door ways, I will have to use thresholds but since the threshold will be on a slab what should I try to use? I don't know if they make thresholds w/ a sticky on adhesive on it to just slap it on. Any ideas on how to do the thresholds??
Thank you
>>SooN<<
UpComingBuilder is offline   Reply With Quote
Old 05-30-2010, 03:21 PM   #2
Pro Flooring Installer
rusty baker's Avatar
I believe that should be "PERGO".
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Baseboard and Radiant Flooring Dilemmas Summiteer HVAC 4 03-13-2010 07:12 AM
What type of Hardwood Flooring for Concrete Slab? talk show host Flooring 5 01-22-2010 09:37 AM
Flooring over slab mike6x7 Flooring 1 01-07-2010 08:42 AM
Radiant flooring question tpagel Flooring 7 05-21-2008 02:41 PM
radiant slab vs. overhead radiant tube holedpiston HVAC 2 05-09-2007 12:59 PM
