Purchase Planipatch To Cover The Old Adhesive ? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 06:29 PM   #1
Purchase Planipatch to cover the old adhesive ?
Quick question....we pulled up the old old carpet and want to lay VCT down. The old adhesive is still coving the entire floor. We have scraped the floor and it is fairly smooth. We were told that the VCT adhesive will not stick to the old carpet adhesive. We were advised to purchase Planipatch to cover the old adhesive. Do we have to do this? Thank you!
jmpkiwi is offline   Reply With Quote
Old 02-11-2010, 07:09 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That is probably some good advice. The Plani-Patch will "take" to the old adhesive residue and the new adhesive will take to the Plani-Patch. In this case I would use the additive to mix the Plani-Patch and not mix it with water.
XXX
How to make a Concrete Cover (Lid) for Septic TanK? mezcalero Building & Construction 1 01-15-2010 01:06 AM
self adhesive cord cover problem willsch49 General DIY Discussions 2 02-21-2009 06:32 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 10:23 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
