Old 09-19-2006, 08:03 AM   #1
pulling up the z bar
When I removed 4 feet of carpet next to two walls in my living room to put down ceremic tile, the guy that cut the carpet and restretched it put down z bar where the carpet meets the tile.He glued the z bar down with epoxy. I want to change the carpet and replace it with wood floors. How do I get the z bars up?
tramp
tramp is offline   Reply With Quote
Old 09-19-2006, 01:21 PM   #2
can you post a photo for a better assesment?
redline is offline   Reply With Quote
Old 09-19-2006, 01:22 PM   #3
I would think a chisel and hammer should do the trick, or maybe a pry bar.
billinak is offline   Reply With Quote
Old 09-20-2006, 04:17 PM   #4
I haven't starting doing it yet. Just trying to see if it is worth the trouble to pull the z bar up or to lay down carpet again. I would have to pull up about 32 feet of z bar. The carpet tack strips on top the z bar are not glued down, only the metal z bar. Will that epoxy come up fairly easy with a chisel and hammer? I forgot to mention it is epoxied onto a concrete slab.
tramp
Price of Pulling Meter off house. Clutchcargo Electrical 23 09-14-2007 06:31 AM
Pulling up tile and laying bamboo on concrete kdhughes Flooring 2 07-20-2007 12:11 AM
Pulling power for new lights TerryL Electrical 2 10-26-2006 09:08 PM
Pulling romex thru wall with old romex? Doug Crf Electrical 4 04-11-2006 10:33 AM
pulling wire through old flexible conduit cbray Electrical 1 05-20-2005 04:55 PM
