-   -   pulling up the z bar (http://www.diychatroom.com/f5/pulling-up-z-bar-3980/)
tramp 09-19-2006 08:03 AM
When I removed 4 feet of carpet next to two walls in my living room to put down ceremic tile, the guy that cut the carpet and restretched it put down z bar where the carpet meets the tile.He glued the z bar down with epoxy. I want to change the carpet and replace it with wood floors. How do I get the z bars up?
tramp
redline 09-19-2006 01:21 PM
can you post a photo for a better assesment?
billinak 09-19-2006 01:22 PM
I would think a chisel and hammer should do the trick, or maybe a pry bar.
tramp 09-20-2006 04:17 PM
no pictures
I haven't starting doing it yet. Just trying to see if it is worth the trouble to pull the z bar up or to lay down carpet again. I would have to pull up about 32 feet of z bar. The carpet tack strips on top the z bar are not glued down, only the metal z bar. Will that epoxy come up fairly easy with a chisel and hammer? I forgot to mention it is epoxied onto a concrete slab.
tramp
