Pulled Up Old Carpet - HELP! - Flooring - DIY Chatroom Home Improvement Forum
Old 01-14-2007, 08:26 PM   #1
pulled up old carpet - HELP!
Please help- I pulled up carpet that was down about 25 yrs, and the backing on the padding has formed a brown gum-like residue on the hardwood floor.Any idea how to remove this easily, some sort of solvent, that can be used to scrape it off that won't harm the floor? What a mess! Thanks for any suggestions, Matisse- new to the group!
matisse is offline   Reply With Quote
Old 01-15-2007, 03:34 PM   #2
Rewards Points: 79
I've dampend it and used a stiff scrub brush in the past.
Tmb9862 is offline   Reply With Quote
Old 01-15-2007, 06:38 PM   #3
re- help for floor-
thanks- thats just what I did but I thought maybe there was something else I could try- and lots of elbow grease!
Old 01-17-2007, 11:12 PM   #4
this may be a similar issue to what I'm facing trying to remove adhesive from the bottom of linoleum that is attached to my hardwood... while I haven't attempted it yet I've heard that boiling water will liquify the glue...
jimmyfunk is offline   Reply With Quote
Old 01-18-2007, 02:53 PM   #5
Chief Fungus Fighter
Talk to a professional flooring installer. There are numerous products out there that can be used to remove carpet glue. The question will be which can be used and won't hurt the hardwood floor. I've used a product called Bean-E-Doo. It is messy, stinky but is soybean oil based so it may not harm hardwood (check first). We used it to get a glue down mess off a concrete floor so we could seal the floor (moisture problems).
MoldBuster is offline   Reply With Quote
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 06:29 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
