Pull Cabinets? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 09:11 AM   #1
Pull cabinets?
I am remodeling a large kitchen that currently has vinyl installed. We will likely put in 3/4" hardwood or something close. Do the cabinets need to be pulled and raised? Or are there other methods to get the proper height? We will be pulling all drawers and doors to paint so this shouldn't be an impossible task, just need help with the best method to get the cabinets to the right height. Thanks!
cebeling is offline   Reply With Quote
Old 05-31-2010, 09:22 AM   #2
DIY staff
Rewards Points: 7,174
It is ideal to remove the base cabinets---install the flooring and reset.
Another method is to add a 3/4" piece of wood (stained to match) on the top of the cabinets--to lift the counter top to the correct height.--That one is tougher to pull off successfully because of the color match.
---Mike---
Old 05-31-2010, 10:11 PM   #3
Rewards Points: 266
we left our cabinets in place and butted the 3/4" oak flooring to the cabinets.
we removed appliances and put oak under the dishwasher, stove and fridge areas.
One thing to consider if you do it this way- make sure you have adequate clearance for dishwasher to fit under countertop with the added 3/4" height.
another thing to consider is if your happy with the cabinets and the layout. If you plan on changing anything now would be the time to take up the cabinets.
What have I done is offline   Reply With Quote
Tiles before or after kitchen cabinets? nipab Remodeling 9 01-05-2015 11:19 AM
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 10:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
