Proper Way To Install Laminate On Stair - Flooring - DIY Chatroom Home Improvement Forum
Old 11-20-2006, 02:16 PM   #1
proper way to install laminate on stair
I am thinking of doing it like this:
install laminate cut to length horizontally with glue and with a special mould at the edge which is the same one used between the transition from laminate floor to carpet, supplied by the same manufacturer.
install laminate on the veritcal surface solely by glue
That's it.
Is this a proper way of doing it? or I should forget about the special mould and screw down a regular stair mould at the edge...
or it is more complicate than that for professional look finished
KUIPORNG is offline   Reply With Quote
Old 11-20-2006, 04:01 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Typically the transition pieces that are made for and sold with laminate flooring are made of paper. They have a very thin laminate coating but below that is compressed paper fiber in most cases. Those pieces used in a doorway is one thing but to use them on a stair tread edge where footwear is slidng and scuffing across the edge daily may not be adviseable. Maybe a metal stair edging would be better.
Old 11-20-2006, 10:42 PM   #3
Floorwizard's Avatar
a carpet transition would not work for long on a stair.
best to use a proper stairnose.
Floorwizard is offline   Reply With Quote
Old 11-21-2006, 08:16 AM   #4
Thanks guys, I will need to return those stuff I bought then... thanks...
a few laminate floor install questions mcvane Flooring 5 11-21-2014 01:34 PM
Choosing the Proper laminate remiami Flooring 6 03-21-2011 04:44 PM
laminate install diyjoe Flooring 15 11-23-2007 02:49 AM
Laminate Stair Nosing/Riser question QuestAns Flooring 1 02-15-2007 08:02 AM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 03:56 PM
