Old 01-20-2009, 12:03 AM   #1
Proper tape for underlayment seams
Hello all,
I'm laying floormuffler on an above grade concrete slab & it says to tape the seams using a tape that meets or exceeds the manufacturers moisture vapor transmission rate (1.39 lbs. per 1000 square feet per 24 hours).
I have a roll of Scotch pro-strength industrial & hvac duct-tape
http://solutions.3m.com/3MContentRet...ersion=current & am wondering if this will do the job or if someone can recommend something else.
Many thanks.
eis61374 is offline   Reply With Quote
Old 01-20-2009, 01:28 AM   #2
Well, this web site:
http://www.shockflooring.com/index.p...roducts_id=127
says that Floormuffler "Exceeds recommended moisture permeability ratings for installation over concrete slabs."
Since any moisture in the slab can evaporate through the Floormuffler, I'm wondering how much of a problem would be created if it couldn't also evaporate out of the small amount of area covered by the taping of the seams. My hunch is that you wouldn't have a problem regardless of what tape you used on the seams.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 04:45 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 10:27 PM
Tape for duct work? Willie5566 HVAC 4 01-16-2007 05:02 PM
Where to begin Boston Painting 4 06-15-2006 07:39 AM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
