Project: Replace Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 05:53 PM   #1
project: replace laminate flooring
I had previsouly posted about my project of replacing the glued engineered wood flooring with laminate flooring here (removing laminate flooring). I finished half of the area last weekend and will be finishing the rest (kitchen/dining area and the half bath) tomorrow.
I have questions regarding replacing the flooring in the half-bath - do I need to remove the toilet and the sink (it is the kind with a small base on the floor)? I have seen a few videos on youtube and they all mention that I should remove the toilet while replacing.
If yes, then what tools would I need to remove and then correctly install the toilet again?
Many thanks,
M
mikeinMemphis is offline   Reply With Quote
Old 03-12-2013, 06:23 PM   #2
Rewards Points: 13,300
You should not be installing laminite in a bathroom.
It's going to get wet and destrory it and it needs to float, not going to be able to move with a toilet bolted to the floor.
Laminate Flooring Installation - Guesstimate This Job For Me Please flowerchick Flooring 8 11-19-2011 01:57 PM
Underlayment for Laminate Flooring nyseguy Flooring 2 04-12-2010 09:45 AM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Questions about and Use of Laminate Flooring ORHarleyman Flooring 3 04-29-2009 01:04 PM
Laminate Flooring Project Questions mhaste Flooring 4 03-28-2009 08:31 PM
