Old 11-01-2012, 07:33 PM   #1
problem with transition from living room to kitchen
this is a mess...i have a problem with a transition from living room to kitchen that I need advice for.. can you help?.. I can send a pic. don't know if the kitchen floor should be pulled up to be level with living room, etc. Laying down laminate 12.2 ml across from living room into kitchen... should I use a step up transition? but that will make for a trip hazard... the kitchen is about 1/2 inch higher then the living room sub floor... help...thank you, tony
tpiro is offline   Reply With Quote
Old 11-01-2012, 09:14 PM   #2
Tileguy
JazMan's Avatar
Hi Tony,
Apparently you haven't ripped anything yet to prepare for the installation. You need to remove the flooring and any layers of 1/4" ply in the kitchen. Once you're down to the subfloor everything should be the same. Evaluate what you've got at that time and then decide how to proceed.
Pics always help.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Replacing carpet in living and dining room. Need advice! mandingo Flooring 2 02-24-2012 12:41 PM
New laminate floors in kitchen and living room Cmonica30 Flooring 5 01-06-2012 04:34 PM
How to handle crown molding transition to kitchen cabinets mystic_cobra Carpentry 6 09-15-2011 03:37 PM
Knocking wall between Kitchen and Living room gatorade Building & Construction 9 02-02-2011 08:56 PM
Suggestions for Living Room gante Interior Decorating 3 03-06-2009 12:56 PM
