Problem With Pergo - Flooring - DIY Chatroom Home Improvement Forum
Old 06-28-2005, 02:55 AM   #1
Problem with Pergo
A couple of weeks ago, I installed pergo presto flooring in my kitchen and it looked great. Now after I finished getting the baseboards on some of the seams on the short sides of the panels are separating to a gap that I can put my fingernail in. Is there anyway to bring them back together? This is very frustrating....
Thanks for any help,
Dave
woodinville guy is offline   Reply With Quote
Old 06-28-2005, 08:28 PM   #2
Contractor
I install primarily Pergo products and have never experienced anything such as you are describing.
It sounds like shrinkage. Did you allow the panels to acclimate? Are the sides anchored?
Teetorbilt is offline   Reply With Quote
Old 06-29-2005, 12:01 PM   #3
I let the boards acclimate for a week. Could changing weather have affected this? It did go from sunny days(When I brought them in the house) to a rain storm(When I installed them). I'm not sure what you mean by anchored? The sides don't show any gaps with the boards next to them.
-Dave
Old 06-30-2005, 09:51 PM   #4
Floorwizard's Avatar
Pergo presto is the most affordable in their line.
It needs all the help it can get with acclimation and humidity control.
What is the humidity at and is it kept constant?
P.S. What does Home Depot have to say about all this?
Floorwizard is offline   Reply With Quote
Old 06-30-2005, 11:29 PM   #5
I did realize there was a difference in quality. I wouldn't have minded paying more for a higher quality but that is 20/20 hindsight. Being in the Seattle area the humidity is normally fairly constant. I was able to remove the baseboards and tighten up the ones closer to the edge. The ones in the middle are impossible to tighten up.
I need to go to HD still.
-Dave
Old 07-01-2005, 08:46 PM   #6
But the problem is when it dries up a bit.
I am from Portland originaly, and I know how wet Seattle gets. But it can get dry too. You would be amazed at how constant the humidity must be for the lower end lams to perform well.
A small humidity detector will pay off in finding out your problem.
Old 07-03-2005, 10:54 PM   #7
Contractor
I'm in FL. Humidity can go from 100% to 50% and have never seen a problem as you describe. I'd be curious as to HD's response.
I've learned to deal with expansion problems but have yet to handle one dealing with contraction.
Old 08-10-2005, 11:07 AM   #8
Retired N lovin It
Send a message via Yahoo to VetteMan
Talking
I have the same problem
Dave ... I have the same problem except that the gaps will appear at random places anywhere in the floor. I install 800 square feet at a cost of over $2800. I got the product at Home Depot. It is the Golden Oak Presto with the most expensive pad underneath that they had ... blue foam. In addition I am having problems with the corners chipping. The laminate chips off. Always on the end or corner about an 1/8 inch in size. Needless to say, I am not happy. The floor is 14 months old.
I am remodeling another home to be used as a rental unit. I went to a local Carpet store ( Max Pie's) in Williamsville, New York for the carpet and tile. In talking with the salesman (I noticed they have Pergo as well) he told me that Home Depot sells an inferior product to that sold by flooring stores. Now, I dont know if this is true or not .. but if true ..... Home Depot is gonna have a big problem from me.
I dont know what to do at this point. Several of the end seams that openned up were in line with a doorway ... I was able to remove the threshold and use the tool to hammer on the end and close the gap.
I spent a lot of money for what I thought was a quality product ... anyone have any ideas????
Dave Stark
VetteMan is offline   Reply With Quote
Old 08-10-2005, 06:46 PM   #9
I would assume you payed very little compared to other lams on the market.
Other than replace with a better product, there is not much you can do to make the product better.
Area rugs to cover I guess.
Pergo Presto diyfred Flooring 14 10-07-2010 04:52 PM
furnace problem captjack HVAC 8 11-23-2007 12:15 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
