Probably Need A Flooring Expert To Answer This One... - Flooring - DIY Chatroom Home Improvement Forum
Old 09-05-2011, 05:54 AM   #1
Probably need a flooring expert to answer this one...
I had an interior drain tile system with sump pump installed in my basement. That system involves a pipe with a "lip" that is cemented into place so it presses against the concrete wall. The concept being that if the walls leak at all it will catch the water and let it flow into the drain tile system below.
SO, my question is about the laminate floor I'm about to install. I see you are supposed to allow 1/4" on the edges of the room for expansion. I'm wondering if I need to put 1/4" spacers against this lip OR if the plastic drain tile lip will be "give" enough to allow for expansion safely. It would be a lot easier if I didn't have to install the spacers just because then I'd have to shim the baseboards off the wall to make sure they cover the edge of the flooring (even with quarter round on the bottom).
I've included two pictures, one with descriptions so it makes more sense. Again, the lip is plastic and a little flexible...but of course I don't want to break it with overexpanding laminate flooring. The second picture is a close up of the lip.
Any thoughts would be very appreciated!
Probably need a flooring expert to answer this one...-photo-2.jpg   Probably need a flooring expert to answer this one...-photo.jpg
kc45 is offline   Reply With Quote
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 11:01 AM
Straight answer on NON-poly finished wood flooring operagost Flooring 2 04-29-2010 09:13 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
