Priming For A Self Leveling Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 09:27 PM   #1
Priming for a self leveling underlayment
I'm going to use a self leveling underlayment in my basement (Laticrete 86) and I need to prepare the floor with the primer. Currently there is some paint on the concrete that the previous owners put down. I have no idea what kind of paint. Some of it flaked off, but most of it adheres to the concrete pretty well. Is it absolutely necessary to remove this paint? What will happen if I just put down the primer on top of the paint?
beckm75 is offline   Reply With Quote
Old 09-30-2009, 10:01 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
It is only absolutely necessary if you want the job to work.
Applying primer to the paint will not make the paint stick better to the concrete. Do as the directions tells you.
"Do not install over painted or gypsum-based surfaces."
Jaz
Old 10-01-2009, 09:32 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The existing paint MUST be removed mechanically. No chemicals can be used for this process.
XXX
Tags
self-leveling
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 04:58 PM
Underlayment under laminate sanramonvalleyfitness Flooring 4 12-31-2008 09:56 PM
LAMINATE STAIR: with or without underlayment nathan.tran Flooring 1 08-19-2008 02:24 AM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 01:12 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
