Pressure Treated Plywood - Flooring - DIY Chatroom Home Improvement Forum
Old 06-16-2012, 01:02 AM   #1
pressure treated plywood
in the state of new jersey can pressure treated plywood be used as a sub-floor over wood joists
clayrob is offline   Reply With Quote
Old 06-16-2012, 01:11 AM   #2
Rewards Points: 558
You should go and ask your building department to get the correct answer.
epson is offline   Reply With Quote
Old 06-16-2012, 06:06 AM   #3
Rewards Points: 13,446
Why would you want to use it?
Pressure treated wood has no place inside a home except for a bottom plate on concrete.
If you went with pressure treated any fastners from then on going into it would have to be ACQ approved or there going to rust off.
It's going to be soaking wet when you buy it, and full of voids. Not a great product to be applying any underlayment over.
rusty baker (06-16-2012)
Old 06-16-2012, 07:36 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Makers of pressure treated wood usually say not to use it indoors.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-18-2012, 12:51 PM   #5
I would just use regular plywood. It will be cheaper.
RhodesHardwood is offline   Reply With Quote
Old 06-18-2012, 03:42 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 340
I
The price has nothing to do with making the correct decision. You do not want PT ply or lumber indoors.
Jaz
Old 06-18-2012, 09:42 PM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
Joe is the only one that stated why you shouldn't use it indoors.
Pressure treated lumber is only used indoors when it is on concrete like sill plates, you need to cut it outside as it has harmful chemicals that release when cut hence why it's wet when you pick it up from store. Termites love pressure treated wood but only when it is indoors. If you google it there are sites that say it is band from using it indoors and then sites saying you can using it indoors just don't eat off it.
I say yeah all we'll and good but your to limited on what you can put over it unless a 3 seasons carpet.
JetSwet is offline   Reply With Quote
Old 06-18-2012, 10:19 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 340
If you google it, there are sites that say it is band (banded) from using it indoors and then sites saying you can using (use) it indoors just don't eat off it.
Yes, you can find all kinds of answers on this crazy internet. After all, there are no restrictions on who can give advice.
Try building a structure with PT indoors and let it dry out a few weeks. You're likely to be re building it. Why? As it dries it'll deform and become loose. It happened to me some years ago.
Jaz
Old 06-19-2012, 08:16 AM   #9
Rewards Points: 82
Also the fumes from it, even tho it no longer contains arsenic, would probably bother anyone who is sensitive to chemicals.
Old 06-22-2012, 09:11 PM   #10
pressure treated subfloor
Pressure treated lumber of any kind is not meant for indoor use by the manufacturer. Your not even supposed to breathe the dust as you saw it technically. Also p.t. plywood usually comes soaking wet and when it dries out it will buck and deform whatever floorcovering you install on it.
Last edited by oh'mike; 06-23-2012 at 06:19 AM. Reason: removedlink---read the posting rules for pros--link below signature line only!
Floor installer is offline   Reply With Quote
Cedar Vs. Pressure Treated???? dobrien1030 Building & Construction 15 04-16-2012 08:47 PM
pressure treated wood project -- acceptable quality? bunchofquestion Building & Construction 6 11-09-2011 09:17 PM
Prep work to stain new pressure treated wood joemessner Painting 0 08-20-2011 05:39 PM
Pressure treated wood Michael Muller Painting 1 08-19-2010 02:33 PM
Best way to attach pressure treated wood to painted siding ? 1freebird Building & Construction 1 09-30-2009 10:02 PM
