Pressboard Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 09-22-2006, 09:11 AM   #1
Cool
Pressboard subfloor
Or at least that's what it appears to be. House built in the 70's located in the Southeast. It has this 1/2" pressboard stuff laid over what looks like some type of 1 x 6 laid diagnoally across the floor joists. Was this stuff common back then? Seems to be a solid floor, but....
I want to lay tile in kitchen, it currently is linoleum. So once I take up the lino, can I just lay some concrete board down and tape it?
I was also told at a flooring store I couldn't put hardwoods down over this stuff, that the nails wouldn't hold.
thanks for any help
Eric_ht is offline   Reply With Quote
Old 09-22-2006, 03:01 PM   #2
If it's particle board that was used for the lino it has to go, if it's OSB it can stay, OSB looks like alot of small pieces of wood glued together.
R&D Tile is offline   Reply With Quote
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 08:37 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 09:06 AM
subfloor for laminate and tiles mf915 Flooring 10 05-18-2006 04:01 PM
COMPLETE subfloor removal alexschmidt Flooring 4 08-02-2005 11:15 PM
