Prepping A Cement Floor For Tile. Carpet Glue Removal?? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 07:02 PM   #1
Lavid2002's Avatar
Rewards Points: 85
Prepping a cement floor for tile. Carpet glue removal??
Hi Everyone!
I'm ready to start laying tile in a basement room. The concrete has come residual glue (apx 1/16" thick max in areas) in the corners to hold down that recycled *foam* stuff that goes under carpet. I don't know how I should remove it. I tried some goof off on a 6" area then found out that is a no-no. Then I found out mechanical methods are best. I can scrape it up at a rate of 1 square foot per 5 minutes with the tools I'm using
How can I get this crap up? My tools don't even get all of it up! Should I scrape the majority of it and call it a day, toss some mud over it?
I saw some youtube videos where people were "grinding" concrete floors and things of that nature. I can totally go to home depot and rent a tool if need be.
Thanks Everyone!! I have a surgery on the 6th for my wrist and I hope to finish this before then. Prompt responses are appreciated
-Dave
Edit: I have an angle grinder that I use for car work, I tossed a flapper wheel on it and it is zipping the floor right up! (Smells terrible!) but it's working great. I feel this surface will be adequate for the mud.
Lavid2002 is offline   Reply With Quote
Old 05-27-2012, 07:16 PM   #2
Lavid2002's Avatar
Rewards Points: 85
Here are 4,000 words...
-Dave
Old 05-27-2012, 07:29 PM   #3
Rewards Points: 13,296
Should be using a scraper like this one.
Make sure to also get some extra blades.
You just not going to be able to get 100 % of, just would on the bulk of the high places.
Old 05-27-2012, 08:27 PM   #4
DIY staff
Rewards Points: 7,174
Soak it with warm soapy water---then scrape as much as you can---
DO NOT USE ANY CHEMICALS--they will drive the stuff deep into the porous concrete--causing a bond breaker--
If that doesn't help--two choices---grind it off with a floor buffer equipped with carborundum stones--
Or--set the tile over the residue---use a high quality modified thinset-
-or mix your own using a liquid latex and unmodified--like Kerabond and Keralastic by Mepei.
I don't think you need to encapsulate that under self leveling compound--but that is a third option.
Old 05-27-2012, 09:19 PM   #5
Lavid2002's Avatar
Rewards Points: 85
Awesome, thanks guys. I will do my best and then lay the tile.
-Dave
The Following User Says Thank You to Lavid2002 For This Useful Post:
oh'mike (05-28-2012)
Old 06-04-2012, 12:39 AM   #6
Lavid2002's Avatar
Rewards Points: 85
I ended up using a wire wheel on an angle grinder, it worked GREAT!. Not a regular wire wheel though, one of those ones rated to 20,000 RPM where the wires are twisted together. It would even eat through the concrete if I let it sit long enough!! Awesome! All the tile is laid as well. Thanks Everyone!
Edit: Like this for anyone looking to tackle a similar project!
http://www.google.com/products/catal...d=0CIgBEPICMAQ
Old 06-07-2012, 05:41 AM   #7
Re: Easy To Maintain Tile For Flooring
-Dave
Hi Mr. Dave,
Thanks for the post. I would like to inform you that there are a wide range of flooring is available in the market so you can choose on of them (most suitable for you) before choosing any one.
Thank you...
sachin_ccil is offline   Reply With Quote
remove outdoor carpet from cement Nancy Pace Remodeling 9 04-26-2011 08:35 AM
asbestos in carpet glue logankevin2008 Flooring 3 05-27-2008 07:59 AM
Removal of old glue hstgonzo Remodeling 4 05-02-2008 04:34 PM
Why is my living room cement floor covered with black glue? sil Flooring 7 10-29-2007 11:03 PM
