Preparing For The Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 08:18 AM   #1
Rewards Points: 95
Preparing for the stairs
I was hoping I could get some advice on how best to handle my stairs.
I'm laying 3/4" hardwood. I'm approaching the top of the stairs from the long wall in the room.
I've discovered that the distance from the last board of the new flooring to the front edge of that top step is not even from one side of the step to the other. It's off by 1/4". It's 34 5/8" in the foreground and 34 3/8" in the background.
To compensate, I'm figuring I'll have to rip the last floor board at the proper angle to meet the stair nose on the top step.
Each step has a lip:
My next question is, am I supposed to cut the lip off and use the board I lay on the riser as the edge for the stair nose? If not, then couldn't I trim the stop step to create the proper angle for the stair nose to meet the flooring?
Any advice would be greatly appreciated. I can supply more pictures if y'all need 'em, if it would help.
Brad Nailer is offline   Reply With Quote
Old 05-04-2013, 10:51 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 552
Cut that over hang off and install a landing tread like below. If the last run of flooring is narrow I would rip the landing tread instead of the flooring as it wouldn't show as bad.
Landing tread.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Need help with stairs rogers_t Carpentry 11 02-26-2013 11:30 AM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
How to finish basement stairs mark2741 Flooring 9 11-13-2012 12:09 AM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 06:13 PM
Strengthening stairs with less support HitLines Remodeling 1 10-29-2009 11:45 PM
