Preparing Dirty Tile For Grout - Flooring - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 11:23 PM   #1
preparing dirty tile for grout
I'll just start off by saying that I do everything ass-backwards. Tile the floor in sections, not grouting while getting wood chips and random dirt in the grout lines (reason being I'd rathe rjust grout all in one shot once all of the tile is laid).
Anyways, what's the best way to prepare the grout lines for this? Would a simple vacuuming do the trick, or do I need to get down with a wet sponge andn wipe out the lines? Either way I don't mind.
Tonglebeak is offline   Reply With Quote
Old 09-28-2011, 11:39 PM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
I think a blower of some sort would blow everything out of the lines.
picflight is offline   Reply With Quote
Old 09-29-2011, 01:34 PM   #3
firehawkmph's Avatar
Rewards Points: 1,800
Tongle,
I would shop vac the grout lines with the brush attachment. If anything remains in the grout joints in the way of debris or goo, wipe it out. If you want to sponge off the tile to make sure it's clean that wouldn't hurt either. You don't want any dirt on the tile to get in the grout. It's also a good time to make sure you don't have any lumps of thinset sticking up in the grout joints that would show through the grout. Take a skinny enough old screwdriver and knock them off before you vacuum.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Tile over Painted Lightweight Cement New_2_DIY Flooring 16 08-28-2011 03:29 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 01:03 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 01:08 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
