Preparing For Adura - Flooring - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 11:57 AM   #1
preparing for adura
Hello there! I am going to be installing adura vinyl luxury tile over existing lino. I have a couple prep questions I'm wondering if someone can help me with.
The existing lino is in quite good shape except for a couple seams that have opened up. Is it best to cut out the problem area and fill with some kind of product? Or should i try staple down the areas to make it a flat surface?
In my hallway, half of it was subfloored and lino and the other half was carpet. I removed the carpet and now have to lay subfloor. What should I do to make the new subfloor level to the old subfloor with the lino? The difference between the two will be the layer of old lino.
The entire area of old lino will be embossed.
Thanks so much for your help.
Terrilynn is offline   Reply With Quote
Preparing to redo fireplace mantel, what to expect? kutsyy Building & Construction 14 01-03-2012 03:45 PM
Preparing for Inspection - I pulled the permit diy2morrow Electrical 4 08-17-2011 03:14 PM
Preparing subfloor for ceramic tile syogod Tiling, ceramics, marble 8 06-22-2011 12:58 PM
Preparing to lay a ceramic floor jrh388 General DIY Discussions 1 09-18-2009 06:02 PM
Question on preparing surface for Ceramic Tile Rferret Flooring 3 07-20-2008 12:08 PM
