Preparation For Vinyl Decking - Flooring - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 01:46 AM   #1
Preparation for vinyl decking
Is it possible to put down plywood on existing deck boards in perpetration for vinyl decking or should the deck boards be removed first then put down plywood? The deck boards are in good shape just wondering about proper structure.
John Stone is offline   Reply With Quote
Old 02-05-2012, 01:51 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I don't know of any reason to take the deck boards off, just screw the ply to it, fill all voids, screw heads etc. sand flat and smooth and install the vinyl as per manufacturer's instructions.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-05-2012, 07:45 AM   #3
DIY staff
Rewards Points: 7,174
Could you clarify where in the house this is?
Old 02-05-2012, 08:02 AM   #4
Rewards Points: 13,712
If your talking about some form of composite decking then all the old deck boards have to come off, if this is an outside exposted deck then plywood is never ever used.
If this is 5/4 decking then your going to have to add more floor joist if there not now set at 16" on center. Composite can not span 24" without sagging.
is the decking over foundation considered structure sn604s Building & Construction 4 01-21-2012 05:02 PM
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Deckmaster--will it work with 3/4" hardwood decking? jbeall Building & Construction 8 03-15-2011 09:05 AM
Suggested Subflooring over pressure treated decking 112690 Building & Construction 2 10-19-2010 07:54 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 06:16 PM
