-   -   Pre slope question on shower floor - did I do it wrong? (http://www.diychatroom.com/f5/pre-slope-question-shower-floor-did-i-do-wrong-38690/)
maestro300 02-19-2009 11:41 AM
I recently pulled out a prefab shower floor to build a larger shower. I have a question on the 1/4" per foot from the drain.
This is a 4' x 4' shower. I just installed my Hardibacker and noticed a "sag" in the mortar between the corners of the floor... which is because I sloped the corners higher since the distance to the drain was further than the walls directly across it. Did I do this wrong? I'm talking probably more than 1/4" of gap difference between the corners and middle of each wall.
From what I am seeing; the floor level should be even across-- but seems to cancel out the original 1/4" per foot that everyone talks about.
So brings me to the confusion on how to start the bottom row of tile. They will clearly show the 1/4" gap line in the middle if I dont correct this. Can someone advise on the best way to tackle? I'll be happy to attach a picture tonight if needed.
Thanks!
Bob Mariani 02-19-2009 12:18 PM
The slope goes to the drain. At the walls it is all level. So you end up with pie shaped pieces that individually slope into the drain.
Mudd 02-20-2009 02:44 AM
Get to grinding and chipping... it needs to be level at the wall-line.
