Praying To The Cement Gods... - Flooring - DIY Chatroom Home Improvement Forum
Old 08-23-2008, 12:42 PM   #1
Praying to the Cement Gods...
Please let my mixture cure to a beautiful, hard, water resistant thing of beauty.
After reading all sorts of possible mixtures and additives and this, and that, and being generally overwhelmed.
Here is what I went with.
5 parts sand
1.5 parts portland cement
Dry mixed together.
Then added sparingly...
A latex bonding additive (mixed with 1/2 water).
Worked it until it was saturated but clumpled in my hand and my hand pulled away clean.
I used this in a test area outdoors to fill some cracks and level out some uneven areas.
If it cures nice (fingers crossed) then I will attempt to use this mixture on the inside slab and as a form for a threshold.
Sound good?
drillbit is offline   Reply With Quote
Old 08-23-2008, 02:12 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Have no idea what your goal is but that mixture isn't likely to last if thin (for a threshold) and being walked on.
What are you trying to do exactly?
Old 08-23-2008, 03:29 PM   #3
Why does this have to be so complicated?
You are probably right. I just did some test areas outside. Some cracks and spots here and there to see how it would cure.
I agree that it looks a little sandy and like it could wash/erode away.
I also just mixed some pure portland cement with water and put that in some places. That comes out more creamy. I'm not sure how it will cure though.
What I want to do:
I have some gaps where the slab meets a concrete retaining wall that I would like to fill. They are not big gaps.
There is an odd brick column corner that I would like to smooth and shape the base of.
Then there is the threshold (s) issue.
I have no idea about the one that rests on a 2x8. I can't figure it out. No standard threshold fits the depth of the sill board and apparently the 3/4" depth is not enough to accomadate tile, barriers, 2 mortar beds and whatever else goes into tiling.
There is another door that opens over the slab. I thought a threshold could be formed out of cement and tiled over in that area.
Yet, that won't work if my mixture is too weak.
Thanks for your response. Perhaps I should give up. I even called a pro, but the job is too small and he didn't want to do it.
It is very frustrating.
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 07:08 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
